Mac SE 240V rocker switch - replacement?
Byrd
Hi all,
I'm doing a SE PSU to ATX conversion for three machines - two are working great, the last has a faulty 240V rocker switch.
I've looked at local electronic stores but none have a suitable match for the rocker switch - noting has has to be the right size to fit past the ABS enclosure.  Any tips, part numbers others have found?
Thank you
JB
Byrd
In my box o' crap I found a switch same height but half size width switch - it'll fit snugly.  There will be gaps either side I'll make up a small plastic shroud to cover it up
