kingchops
I tried connecting the macplus to my pc via a serial cable. Cable on the macplus end has a din connector that goes into the plus's printer or modem port and a 25 pin connector that I've attached to a null modem cable then into the pc via a usb to serial cable. I know a lot of cables. Last time I used the null modem cable between two pc's it worked and I've also used the usb to serial cable for other things and that also worked.
I tried connecting the two computers via a temninal program. On the plus I used the one that comes with Claris works and on the PC I used Tera Term and no go. I tried many different baud rates etc and it doesn't seem like the two are communicating at all.
Does anyone know if this configuration should work?
