tjjq44
Maybe the SCSI2SD doesn't meet exactely the real old HD specs... As anyone asked the developpers to find a solution?
A trick to get around the problem (with system 6 only) is to boot from a floppy, then double click the finder file from the HD with command & option key pressed. Then, until next reboot/shutdown, the startup disc will remain the HD (system software versions must be identical on floppy and HD)
