Mac Plus and using a zip drive as a hard drive
equant
Awesome stuff. Nice effort.
What is this WetII (WetII?) you speak of?
I use a netgear wireless printserver (WGPS606) as a wireless bridge for my old macs. It also makes a great wireless print server. Go figure.
Does MacHTTP require system 7?
macclassic
Ooops!, I meant a Linksys WET11 wireless/ethernet bridge.
I had my eye on the Netgear wireless printserver (WGPS606) once too as it has fantastic spec but was expensive at the time. I should move one up my wish list!
I 'think' MacHTTP requires system 7.x and MacTCP, but Fetch needs MacTCP so you end up with System 7.x
Still having fun.
numero6
Hi all,
My plussed 512 has been collecting dust on a shelve for a while... now I've plugged it again but I'm still stuck with the same problem.
It boot Ok from floppy (system 6.0. 8) , but I can't make it boot from an external (SCSI) drive. I tried with Zips again and with a 3gb hard drive that I formatted using different applications (Lido, Blue Disc Manager, Apple Special HD 7.3.5). The Zips and the drive mount Ok after formatting but not after rebooting the Mac :disapprove: I have to use a mounting app. to make them appear again. So the Mac can't boot from them although I installed the system on them . I tried various formatting formulas and the result is still the same !
Anyone can help ? I think I'm just missing something and it drives me crazy ! I have great projects for this little Plus but right now I'm stuck
tomlee59
Few drives >1GB will boot the Plus, in my experience, thanks to the not-quite-compliant SCSI implementation of the Plus (it was the first, after all).
As for the Zip problem, though, you should be able to get that to work with some more fiddling. Here are some things to try:
1) Experiment with different power-on sequences. Sometimes it matters whether the boot volume is powered up before or after the computer. Also experiment with "disk inserted prior to power-up" and "disk inserted after power-up" (just in case that makes a difference with your setup).
2) A terminator is necessary, but the Plus does not supply terminator power. A device external to the Plus has to supply that power. Depending again on power sequencing, it could be that the bus is not properly terminated during the time the Plus queries the bus.
3) Try installing a fresh v4.2 driver. If that disk has been used in a system with a more recent version, the driver might have been modified without your noticing.
Mac128
That is a good point. The ZIP disk is the most reliable SCSI drive I have ever used with a Plus. Plug-N-play if formatted correctly. I personally usethe 4.2 driver method and have never had a problem. Charlieman has suggested using Lido or other low-level formatting software will be just as effective. He will have to weigh in there. Numero6 did not mention which method he used on the ZIP.
However, If you are using 6.0.8, install the Iomega 4.2 driver in the Sytem Folder and simply erase your ZIP in the Finder. Copy your system over. Confirm it is there and double click on it, just to make sure it is recognized as a valid System file. The ZIP must be on, terminated, and the disk inserted before or immediately after you flip the main power switch. Your Mac Plus should then boot from it.
If it does not, then there may be a problem on the SCSI bus. Also, what version ROMs are you using? If a first revision ROM, there could be some issues there as well.
tomlee59
I used the same formatting/system install method that Mac128 has described, and that has worked well for me. I have not been diligent about documenting which ROM versions are in which Plus, but they all seem happy with Zips.
numero6
Hi eveyone...
and thank you Mac128 and tomlee59 ! My Plus now boots from the Zip flawlessly... as I thought I was close but after trying so many formatting settings I was "dizzy" and had forgotten the basics...
Now I can focus on the next 2 challenges : to fit the (internal) Zip drive into the HD20 case (and manage a space so I can push the cartridge into the drive) and to connect the Plus to my 12" Powerbook (G4) and then to the Internet... through a Farallon Etherwave localtalk-to-ethernet bridge.
I guess this will be more complex ;)
Thanks again for the help :-*
Mac128
While this makes me cringe, the reality is that once an HD20 drive is dead, there is no known way to replace it. So it's not like trying to preserve it will ever result in anything more than a nice looking empty case. In which case, modding an HD20 case to make it useful seems like a reasonable option.
I had thought about using an HD20 case for a slot-loading CD-ROM, by using the side air vents with a minimum of alteration to the case. This could of course be used more efficiently for the ZIP disk, to eliminate major alterations, as long as the dies of the drive is exposed to access the disk. I had also thought of doing this with an old 400K or 800K external drive, but those can still be restored with functional drives. And the HD20 case will hold both the SCSI Zip, much of the bulky cable and the external power supply. One could even put a power strip in there in order to power the entire Mac system with a single cable. All the Ethernet hardware can be put in there as well. So, it sounds like a good little project.
numero6
I'm already using the HD's power supply for the Zip drive (it's an internal one, taken from an old G3). The drive fits perfectly in the case and there is some space left, but not enough for the Etherwave I think.
I will shortly open a new post about connecting the Plus to internet...
Mac128
Aiiiiiii!!!
Thant's not an HD 20, that's an HD 20SC which has a significantly sustainable, preservable life, as it is the original SCSI drive case.
Now I'm back to cringing. Whatever you do, DO NOT cut holes into that case. It would just be wrong, especially if it is branded 20 SC, there are not too many of those left in circulation. I would suggest making a spacer to hold the top of the case just high enough to insert the ZIP disk. Either that or cut your slot into the side vents already cut into the case to alter it as little as possible in the least visible way.
numero6
Don't worry I won't harm it ! I like old things too much ;) I'm currently using a Ericsson T39 phone and a Nikon F2 camera daily...
I plan to use the space used originally for the HD activity LED (which is useless now) to be able to push the the cartidge into the drive.
Or is there any software to stop the Mac from ejecting the cartidge ?
