Snial
OK, so it's an intriguing problem. Oh, right I see I haven't given my location, but it's in the UK, so that limits the support, but it's OK, I / we / the group will learn something. I have a version of Tiger that had been running on that mini G4. I guess, regardless of the formatting, why would it show up under OF when it's powered just with USB and not with the extra 5V input, especially as I can see from the tracks that they're the same?Okay, perhaps even “weirder Plus”… the half-sized card mSata adapter (typically comes with a white case) will not run in a G4 Mac mini unless the little voltage selector is set to 5v. The “full-size” mSata adapter does not offer that option - but still functions fine.
All pictured in #9 post above.
Won’t even delve into the MCA004 and the AS331 bridge adapters (also pictured #9 above) that are nearly completely identical - but the MCA004 often fails to boot while the AS331 boots the mini without fail. (Of course the AS331’s can no longer be sourced.)
I have some options. An obvious one is that I could use my second mSATA and IDE adapter directly on the mini G4. I first used the drive with the macBook C2D via the USB +5V and when it didn't work I took the 5V out. I can also check the voltages on the mini G4 ATA riser.
I'll remember what you said about HFS+ Journaled.
