I got this Mac IIsi a year ago. Removed the battery and all caps then. Didn´t test it before that. Now I have started to get it working. All caps are replaced with tantalums, new axial caps.
When I turn it on, the fan is working, HD is spinning. The screen is white with no mouse pointer. Only a click from the speaker but no other sound. The PSU is fine, I have also tested with o PSU from a working Mac IIci, same result. No RAM SIMMS, no ROM SIMM. pin W1 is enabled. I guess the IIsi should boot with the RAM on board. I have checked several times for corroded traces but not found any . Also checked the new tantalums for correct capacitans. The speaker is OK. Same result without HD and floppydrive.
I have read "Troubleshooting Your Macintosh" by Douglass High
page 85:
"Hardware initialization
A typical Macintosh hardware initialization consists of the following events:
1. Power is applied to the system.
2. The power supply establishes the appropriate voltage levels required by
the system.
3. These voltage levels typically are monitored by one of the Sony sound integrated
circuits on the logic board. If the levels are acceptable, a reset signal
is then generated by this IC.
4. This reset signal forces the central processing unit (CPU), math coprocessor
(FPU), primary logic ICs, expansion cards, and other internal devices
to come to a known state.
5. The reset signal is withdrawn.
6. The CPU obtains the reset vector (typically four eight-bit words), which
begins at memory address 0000 0000 (hexadecimal). A ROM overlay
address map then is used by the memory decode and control circuitry to
map the standard memory locations to a ROM address. The CPU goes to
the reset vector memory address, which is now mapped to ROM.
7. Special program code called the Macintosh reset handler (MRH) is executed.
The MRH remaps ROM and RAM to their respective locations.
8. The MRH initiates the P.O.S. T. sequence."
Is it the sound chips thats not working? Defect RAM? The soundchips UB7 and UB8 is closest to the caps C9-C11 .
I´m greatful for any advice.
page 85:
the system.
