gogopuffs
This may be an easy one for you. I got a barn find battery bombed Mac IIci (Thank you @AppaloosaMac for the Mac Barn Adventure!) and I am pretty certain that it was stored for years vertically on its side, enabling the battery acid to pool on the side of the case and eat into the power supply metal instead of the traces on the board. Pretty lucky actually!
So, after a gentle clean, the thing boots and seems mostly happy, but definitely could use a recap as well. In addition to changing the caps, I'd like to put in replacement battery holder.
Two related things - are there a continuity test points (or alternately the correct RTC pin) that I can see if the battery vias are still viable (pun intended) and/or if they are not, would that test point be viable for a bodge wire to restore functionality?
RTC chip Pin 10 for ground (battery negative) or tracing over to the ground on the HDD power adapter and the leg of the D8 transistor?
Look at that beautiful (carnage) patina as I found it.
After a gentle cleaning and a zoomed out photo. You can see where that battery acid just ate up the metallic paint shielding on the inside. You can see how almost everything else looks perfect though.
Thanks for your help!
