bunnspecial
I have a Mac II around here that I've worked with on and off for a while. I suspect it needs a recap(or rather I'm sure of it), but thought I'd ask and see if there's something else I could try.
Basically, when I first received the computer it was dead as a doornail. I was advised to replace the PRAM batteries, and while I was a bit skeptical of that working, I ordered two new batteries with solder leads and replaced them.
After doing that, I'm able to get the board to chime. It will also play the chimes of death if I remove the RAM. I THINK it's accessing the HDD, although it was supplied to me with a 10K laptop SCSI drive and adapter so I don't have an access light and can't really hear it clearly one way or another.
The problem, though, is that I can't get any video output. I have a decent stash of NuBus video cards ranging from the basic Mac II color card up to a couple of Radius 24x series ones. I've tested and confirmed all the cards I'm using work in both my IIci and Quadra 700. I've also tried every slot on the Mac II LoBo to rule that out.
Just in case, I've also swapped RAM. I've tried it with known good 1mb sticks pulled from an SE, as well as other combinations too numerous to list.
I did wash the board, although I don't see any obvious leakage or other stand out issues.
Does anyone have any ideas of places I could look or things I could do aside from throwing new caps at it? I'm not set-up to do recapping at home, so I'll have to send it off and don't want to send off a board on the assumption that that's the only thing wrong.
