New member here with a few questions ...
I pulled out some old equipment out of the attic in preparation for the local ecycling drive, then found this place. It has inspired me to try to find a new home for the equipment (at least as parts). If not, I'll take it to the recyclers next year.
In any case I have a Macintosh II and a Macintosh IIcx, both with issues.
1) The II is completely nonresponsive. It worked last time I tried it (many years ago), so I am assuming that the problem is the batteries. It also missing a HD. Rest of the specs: 8MB memory, Macintosh II video card.
2) The IIcx appears to work. The HD in the system was nonfunctional, but I was able to use the HD from the Macintosh II to start it up and poke around. In the process, this HD also failed, so I can't continue. The floppy drive is not working, by the way. Specs: 8 MB memory, Machintosh II video card, Farallon Ethermac card.
Questions:
1) Looking at the forums, the standard advice appears to be to replace the Mac II batteries with battery holders, then use standard batteries from now on. Is this a standard part I'd find at Radio Shack, for example? Having never soldered anything, is this something I'd likely be successful at?
2) I have a number of old SCSI HDs that work, with various versions of the OS on them (7.5.5, 8.1). None of these are recognized by the IIcx (flashing icon indicating no OS found). If I hadn't been successful with the old Mac II HD, I'd have guessed that the IIcx couldn't read any HD. Is this simply a matter of "blessing" an old enough version of the OS on the other HDs, or does it need a particular kind of SCSI HD?
My one working system from the attic is a Centris 610 (upgraded to a Power Macintosh C610 with a 40MHz PowerPC 601) with 52MB memory. I also have a couple of working AppleColor High Resolution monitors, an Apple Portrait monitor (B&W), an Apple Multisync monitor, keyboards, ...
but I'll save this list for the Trading Post forum. There used to be a kindergarten teacher in town who collected old computers for his classroom, to run games on etc. He has since retired. Any other suggestions on how to identify new homes for these systems (assuming that I can resurrect the II and the IIcx)?
Thanks.
Questions:
Thanks.
