sambapati87
Okay, I've read the famous PDF about classic mac procedures, and I'm pretty sure I need to fix the solder connections on the J1 connector. I'm a little unclear on exactly what to do, however.
I've circled what I believe to be the 4 solder "points" (not sure on the correct terminology here) that need fixing. There are blatant burn marks on the little foam pad that holds the cardboard protector to this part of the board, and I can see black around at least one of the joints. Should I try de-soldering these, then starting over, or can I just add a dab of solder to each one and be on my way? I guess most importantly, is the area I've highlighted in this image where I should even be looking?
FYI I'm not completely stupid when it comes to electronic pieces like this, I just want to make sure I know what I'm doing before I dive in with a soldering iron.
