habibrobert
Hello,
I just aquired a Macintosh LC II and its 12 inch monitor from a friend of mine who got it at an estate sale. When I hooked everything up and turned on the LC, I saw that the screen was dark. So I waited a little while and then suddenly an image came up. It was just a gray blank screen (I have attached a photo of what it looks like). There is no floppy icon or no question mark visible. So here I am stuck with trouble shooting. I can't tell if it is the monitor's issue or the computer. Here are my findings on each:
The monitor:
It seems to function correctly, however on the back end of the monitor, there are three little holes with little pictures underneath it describing how their function would help center the image. There were no knobs there, I don't know if they were broken off or what? I also have included a picture of what this looks like. Is there anyway to test if this monitor is working properly? I was wondering if I could hook it up to my pc and via a DB-15 to VGA adaptor to see if it will get any image. Will that work? I don't want to risk damaging the monitor by sending it incorrect signals.
The LC II:
When this gray screen first appears, you see the screen flicker with a horizontal line. At the same time that this is happening I hear a little "tick" sound coming from the computer. I turn off the monitor to confirm that it was not making the noise and sure enough it was coming from the speaker. I unplugged the speaker to confirm this and the screen still flickered, but there was no "ticking" sound. Each "tick" was associated with a flicker on the screen. In other words, they were synced up. Now, after a while of leaving the computer on, the ticks disappear, and so do the flickers and it is just a gray screen. Note that when I turned on the computer I heard no chime. Just for the heck of it, I was curious if the monitor would still show a gray screen if the VRAM was taken out, and surely it did.
So I am confused as to what to do. Has anyone had this problem before? Anyone got any suggestions on what to do? What do you guys think is the culprit? The monitor, or the LC II? Also, is there anyway to enter into the Mac's bios like on a PC by pressing certain keys on the keyboard? (sorry I'm a little new to macs).
Any input is much appreciated!
The monitor:
The LC II:
