LC III refusing 7.1
Gil
After my LC III sat unused for a few months, which had/has bad caps. So I removed the ROM's and washed the board. I probably screwed something up by putting the ROM's in the wrong way ( 8-o ), but the computer worked after I corrected the problem. Now, I tried to install System 7.1, but when I boot to the installer disk, it says "System 7.1 does not work on this model; you need a newer version that does." HOWEVER, it happily boots to the System 7.1 Disk Tools disk. I booted my LC 575 from the installer disk, and it boots fine, so there's nothing wrong with the disk.
Could I have mucked something up when I put the ROM's in the wrong way? xx(
Gil
Darn, I didn't think of that. It worked! Although I don't remember having to use an enabler in the past. :-/
Dog Cow
I have the full set of LC III System 7.1 Install disks which I can send you (via .img disk image) if you would like.
