But if the SCSI cable between main board and hard disk is broken, that would be an excuse, wouldn't it?
Yeah, but that'd be like when a thin piece of metal (like aluminum, about the thickness of a soda can)
somehow worked itself into the oil pump gears on my '88 325is. (Yes I did shut the engine off, and confirmed no oil pressure the next day by taking off the oil filter and holding rag next to the filter input direct from the oil pump. The piece of metal had jammed the pump gears, but the engine didn't know any better and snapped the oil pump drive shaft like a toothpick) It's like... :-/ "how did that ever happen??"
Since you have successfully booted w/ 6.0.8 from that floppy drive, we can assume that the drive is O.K. Have you ever booted another Macintosh w/ that 7.5 Network Access Disk? Can we assume that the 7.5 NAD is not defective? Just an idea.
The 6.0.8 floppy you have used to boot up the SE/30 is a 1.4MB diskette, isn't it?
I do not have another classic Macintosh. I have three Macs here: SE/30, iBook G3 900MHz 32VRAM, and a Mac mini 1.66GHz Core Duo with max RAM. (Call it collecting all three breeds of processors.
The 6.0.8 disks can be either 800K or 1.44MB, but the system you saw above is 6.0.8 loaded from the floppy onto the RAM disk. System 7.0.1 boots fine, I'm sure 7.1 would work also, but I can't figure out why a plain vanilla System Folder with System and Finder from 7.5NAD will not boot, even when blessed. The drive rejects the disk.
I should get working on seeing if I can load Ethermac drivers and connect to my iBook for easier filesharing. Floppies are not a reliable means of file transfer or backup - heck the 6.0.8 boot disk with the RAM disk application somehow unblessed itself, and thus I had a minor scare about not being able to boot with anything.
