You have to wonder how accurate they are and why Apple would allow them to be sold contemporarily with their technology.Beck-Tech sold the schematics so there should be a few copies around.
Since we've determined the C16 directly interfaces with the power supply into the RTC it is definitely worth replacing if it looks suspect anyway. However, I don't think you can conclude it is not the RTC without actually swapping the known good RTC for the bad. Try the C16 first (perhaps borrow the one from the good board), then swap the RTC if that doesn't work.I purchased a 512Ke on eBay (arrived Friday) and swapped logic boards. Clock worked. So it confirms it's something on the logic board. I'm still focusing on C16 as it looks damaged.
The 512K and HD20 had entirely different logos from the picture that showed the corrosion (and LC?). I wonder if the diamond-cut inlaid logo was stamped out of a steel alloy while the square 3-D logo was stamped out of something less reactive with the H202 like aluminum.The Apple Logos and Labels - undamaged (I did not remove them - watched closely).
Interesting stuff. I can remember using something like it to clean my mom's patio furniture in Florida. It must leave some kind of film on the case in order to work, though I assume it is undetectable? As such, it would seem necessary to reapply to maintain effectiveness. This is a good solution since it should allow for repeated dunkings as the unit yellows from heat and chemical breakdown. Would be nice to leave it on display in a sunlit room without having to worry about the UV degradation which seems to be ironically both the Mac's main nemesis and savior.I've been using "Aerospace 303 Protectant" on them. The 303 Aerospace Protectant has a UV block.
The 303 Protectant is nice because it does not make the plastic look wet or feel slick like Armorall does. It gives the plastic a "new" look.... The UV block is a bonus. Not sure how long that lasts, but after the H202 dunk and the 303, the plastic looks brand new. I'm pretty pleased.Interesting stuff. I can remember using something like it to clean my mom's patio furniture in Florida. It must leave some kind of film on the case in order to work, though I assume it is undetectable? As such, it would seem necessary to reapply to maintain effectiveness. This is a good solution since it should allow for repeated dunkings as the unit yellows from heat and chemical breakdown. Would be nice to leave it on display in a sunlit room without having to worry about the UV degradation which seems to be ironically both the Mac's main nemesis and savior.
The gray paint has a metallic content. The whole point of it is to prevent RF interference. Given that the RF shield is aluminum and the Apple III used a solid aluminum chassis, my guess is, it's an aluminum based paint. Aluminum is not particularly reactive with H202.I'm not sure about the content of the gray paint used on the interior.... Mine looks fine after being dunked.
the spacebar on the keyboard of my 512Ke looks pretty good - that took 4 days out on the sun and 1/2 to 1/3 3% solution to get it looking that close to the other keys - it's a harder plastic...
I did notice that any screws put unto the H202 solution suffered from minor corrosion (steel?) I think you may be right about aluminum. Also, I am using a much lesser percentage of peroxide - compared to the solution that ate the Apple logo in the earlier picture that I linked to.The gray paint has a metallic content. The whole point of it is to prevent RF interference. Given that the RF shield is aluminum and the Apple III used a solid aluminum chassis, my guess is, it's an aluminum based paint. Aluminum is not particularly reactive with H202.
As for the spacebar ... that explains a lot, in particular why it tends to discolor and the other keys do not. Clearly supplied by a different manufacturer. Did you dunk all of the keys as well as the spacebar? If so, how long did they take by contrast?
The screws would most definitely be steel, cheapest of all the screws and no reason to use anything else. Actually you may be onto something re: the aluminum reacting with steel. The coating is judiciously applied and no metal parts come into contact with it at all. Of course they couldn't for electrical reasons. In fact, the only part that does come in contact with it is a specially designed aluminum strip mounted to the case that comes into contact with an aluminum patch on the analogue board left exposed through the vinyl. As Apple's tolerances were ridiculously tight, they later added a plastic liner that ran the length of the logicboard extending from the RF shield to prevent any contact by the chassis or logicboard caused by misalignment. I believe the steel chassis is further coated as well, though the sharp edges certainly defy any protective coating.I did notice that any screws put unto the H202 solution suffered from minor corrosion (steel?) I think you may be right about aluminum. Also, I am using a much lesser percentage of peroxide - compared to the solution that ate the Apple logo in the earlier picture that I linked to. ...
Apple would have to be careful with any aluminum - based paint. If it came into contact with steel parts/screws - Galvanic corrosion.
I asked Lumpy about "tablespoonfuls" of this powder in a previous post, but the instructions talk about "scoops" with the included plastic scooper. Since the scooper holds more than a tablespoon, I assume you meant "1 scoop" instead of "1 tablespoon" correct? But even at 1 scoop per gallon, it is still less than the "SOAKING" and "HARD SURFACES" instructions recommend. Those instructions say 2-4 scoops per gallon of water.USAGE GUIDELINES1) Test in an inconspicuous are first. Rinse, then allow to dry. Always follow the manufacturer's instructions for water temperature and for cleaning garment or item. OxiClean works best in warm to hot water. Treat stains while fresh. Always rinse well with cool water. Do not place fabric that has not been thoroughly rinsed into dryer.
2) Do not use on wool, wool blends, silk, silk blends, leather or on fabrics labeled dry clean only. Not for use on jewelry, latex paints, woven baskets, unpainted wicker, jute, teak, or finished woods. Metals must not be soaked and must be rinsed immediately and thoroughly. Not for use on rust, dried paint, or bleach damage. Safe for septic tanks.
3) Keep container closed and dry between uses.
4) Some stains require repeated, longer or stronger treatments. Adding more OxiClean powder than recommended increases the risk of color loss. If washing in cold water, pre-dissolve OxiClean first in 16oz of warm to hot water. Add to cold water/wash.
WARNING
...AVOID PROLONGED CONTACT WITH SKIN...WEAR GLOVES WHEN MIXING OR USING SOLUTIONS. DO NOT STORE UNUSED SOLUTIONS FOR MORE THAN 6 HOURS, AS PRESSURE CAN BUILD UP AND RUPTURE THE CONTAINER AND CAUSE INJURY.
For durability when inserted by machine tools and/or idiots, most computer screws are steel and have a bright plating which serves no engineering function. Case screws have coarse threads because their security is unimportant and the female thread may not be well formed. Some screws are japanned (ie given a gloss black coating) for aesthetic reasons, similar to plated screws. In the early days, Dell and other PC clone manufacturers used plain steel screws. PC motherboards are secured by brass mounts which use fine threads -- I don't understand the reason for this, unless it is just copying what IBM did donkey's years ago.The screws would most definitely be steel, cheapest of all the screws and no reason to use anything else.
Inside a compact Mac, the RF paint is probably aluminium and carbon suspended in acrylic. The paint is too grey to be aluminium on its own.Actually you may be onto something re: the aluminum reacting with steel. The coating is judiciously applied and no metal parts come into contact with it at all. Of course they couldn't for electrical reasons.
The chassis is painted for rust protection. It was almost certainly brought into the assembly plant from an external supplier, in the same way as a floppy drive or CRT tube. It was probably dipped rather than sprayed -- if you were spraying it seriously, you would perform a second pass to cover the rounded corners properly.I believe the steel chassis is further coated as well, though the sharp edges certainly defy any protective coating.
Are you trying to wash your colored laundry or restore your Mac? LOLI did find it interesting that the label recommends "warm to hot water" (apparently to dissove the OxiClean powder). And yet they recommend rinsing in cool water. Not sure why cold is required for the rinse.
