Jaz Drive with System 6
Anonymous Freak
Is it possible to use an external Jaz drive with System 6?
Thanks,
agg23
Yes. At minimum, you boot the system with a disk in, and it will treat it as if it were a fixed hard drive.
I don't know if any version of Iomega's ZIP Tools or "IomegaWare" will work with the Jaz drive under System 6, though. (I know there's one version of ZIP Tools that supports System 6, but I don't know if it supports a Jaz drive.
Anonymous Freak
It would help, since System 6's HD SC Setup won't be able to partition it. But it *MIGHT* pop up as "unformatted disk, would you like to format?"
