drybones99
My Macintosh Plus is hooked up to an original Macintosh Keyboard M0110, and many of the keys are intermittent/unresponsive. Playing Prince of Persia became almost impossible, as did typing. I tried using WD-40, and then, when that didn't work, I tried desoldering the switches and cleaning the contacts with contact-cleaner. That didn't work either, so I have decided that the best choice would be to replace the intermittent switches, and perhaps all of them. I need to know what exact switch the Macintosh Keyboard M0110 uses, so that I can replace it. The switch needs to feel the exact same, and preferably be the same color. Can anyone link me to that exact switch on Digikey/Mouser or a similar site?
