olePigeon
Both of my IIfxes had the C1 capacitor blow up. If I remember correctly, so did quite a few other users on here. I'm beginning to think that the general recommendation for any IIfx should be to replace the C1 capacitor with a higher rated capacitor. It's possible it can crater the pads, forcing you to use the other set (which is what happened on the NASA IIfx.)
