IIci Odd HDD Issues
Schafeman
So..  I've been building up the 'ultimate' IIci, and i'm almost there.  My selection of SCSI HDD's is limited these days, and all I have left is larger drives (9gb or more) besides the 500mb Apple drive I currently have in the system (which is very noisy and slow).  I have a 9gb drive in an external case i've been trying to get working with it, and I can go as far as partition it into 3 drives (and initialize them) and have it work great UNTIL I reboot the computer.  They never re-mount, and when I go into Drive Setup, it gives me the whole 'you don't have a 68040 or PowerPC and can't use volumes larger than 4GB'.  Now, if I re-partition and initialize again, it will work great again until next time.  Any ideas?   I've tried partition sizes as small as 1.8GB but I still have the same issue.
olePigeon
I was going to recommend 2GB partitions, but nevermind, you already tried that.
How about partitioning to a single 2GB partition, leaving the rest unallocated?
Schafeman
It pains me to waste all that space, but I haven't tried one partition yet.  Will do later tonight and see what happens.
Schafeman
Unfortunately that did not work either.  Very odd, but it must be its detecting the total size of the drive and refusing to use it, even though its in smaller chunks.  Oh well, SCSI2SD time.
Schafeman
*Update* - After I found my copy of Hard Disk Toolkit, I let it do its 'Auto Initialize' thing and it works perfectly.
techknight
Yea you never specified what formatting software you used. It could have an older disk driver that is buggy on the 040 with larger drives
Schafeman
I was originally using Apple Drive Setup to prep the drive, and it always said it worked fine, but then would act strange after a reboot.
