ToneMalone
Hey all,
Wondering if this is an issue others have run into in the past.
I have an LCIII that I've recapped, and did an 'overclock' so it identifies as an LCIII+ now.
It has the 68882 FPU installed, 32mb ram (128mb w/ virtual), and vram chip. Tattletech sees everything as it should.
Before the recap, the clock would reset after every reboot even with a fresh battery. This issue has been fixed with the recap. working great for a cpl weeks.
I have installed OS 8.1 on my SCSI2SD w/ 32gb SD Card with a 2gb partition for boot and x2 10gb partitions for files.
Everything loads fine, programs seem to run, I've logged hours into simcity 2000
lol.
I HAVE transferred some large programs to my 10gb partitions without problems;
But now when moving or copying any file larger than about 1mb the finder crashes, i lose all my icons for a moment and it eventually restarts Finder only having transferred a portion of the file.
Seems like an odd intermittent issue, and I haven't figured out how to trigger it or fix it.
Any ideas? Could this be due to capacitors? Is it my partitions or scsi2sd setup?
Thanks for any help
Cheers - Tom
Thanks for any help
Cheers - Tom
