IIci no boot
Aoresteen
Dug my IIci out of storage and pluged it in. It powers on with the keyboard switch but:
1. no chime
2. no video. I'm using a VGA adapter that works well with my Quadra 605.
So I took every card out of it. changed the battery with the one from my Q605.
Took all memory out except two sims.
Same deal. No chime or video. Hard drive spins, power light comes on.
What's next?
coius
I know you took out the PRAM battery, but check the voltage. The quadra may run fine, but i recall the II** series require a fully working PRAM battery to display video. Even if it's adequate voltage for the quadra, it may not be for the II series mac
Dennis Nedry
With no chime, I suspect capacitor leakage. You should get some sort of sound with a dead battery, either a chime or a crash. I run my IIci's with no batteries for fear of the dreaded explosion.
If you have ever had a leaky battery in a IIci, acid will go through a hole in the bottom of the plastic battery holder onto the logic board and eat a trace that goes to the ROM chips. This can only be found by unsoldering and removing the battery holder and inspecting the traces.
Aoresteen
Dennis,
When I changed the battery I looked for leakage and found none - board is clean around the battery area. I guess I'll have to re-cap it. When I do I will pull the battey holder and look closer.
CelGen
When you are in there recapping the thing, also solder in a CR2032 battery holder so you can use something less expensive. I've had good luck with them as alternatives.
trag
As an aside, the IIci is one of the machines which does not need a good battery in order to boot properly. When a IIci won't boot, replacing the battery will never fix it.
As others wrote, it's either leaking/bad capacitors, or a failed power supply.
AichEss
The RAM slots in a IIci are in two groups of four slots. You need a minimum of 4 (same-size?) RAM modules to fill one bank.
Unknown_K
As mentioned you need to install RAM 4 at a time and they need to be the same size. Since the internal video uses RAM without a good set of RAM you get no video. Also just because the VGA adapter works on a quadra doesn't mean it will work on a 030 class machine with built in video (they tend to not work at higher then 640x480 resolution and are picky about using sync on green monitors).
theos911
I have the VGA adapter for use with my minidock and a duo. When plugged into my monitor it works fine at 640x480x60 and scales nicely. However 832x624x75 doesn't work. I'm not sure why, but I do know that my monitor does not like 75hz and that is part of the problem. (75hz doesn't work under windows 7 either)
Unknown_K
832x624 is not a normal PC type resolution, some monitors will not support it (Sony CRT ones will). Newer LCD monitors might not like it either (just checked and this Samsung monitor doesn't give me that resolution).
