I saved 100+ iBook G3 Clamshells
novusgordo
What would shipping be to here, I wonder? (slow boat is fine, use postal code V5V 1A1 for calculating rates) I probably shouldn't, but it's soooooooooooo tempting...
bunnspecial
I received one of each color on Friday, and they look great!
Both fired right up and-amazingly-have working batteries. I haven't tested the battery life yet, but it's at least enough that the computer will completely charge and will stay asleep if unplugged. Anything is a big improvement for me over my other Clamshells. I have a mix of factory and aftermarket batteries, and all are dead as a doornail.
In any case, I did have to do a bit of OS 9 magic to defeat the password on the tangerine, and ended up reinstalling OS 9 so that I could get the "official" OS 9 Tangerine desktop back.
I couldn't be happier, though. The ones I received have writing on the bottom rather than the top. I'm a chemist, and am going to take my time trying to get it off.
Thanks again!
tunster
New member
@belgaonkar - what a save! would you consider international shipping to the UK? i'm keeping an eye out for a tangerine model and they don't appear on eBay very often hear.
belgaonkar
I should be paying rent at the post office  ;)
Im all out. As mentioned I have saved 10 and plan on swapping some of them with G4 chips.
just.in.time
Congratulations on moving that entire lot.  I hope you made some decent profit for all the space they took up and the time you invested.
My Tangerine I received from you is still working great.
I don't think I'd do a G4 conversion.  However, a 1024*768 display panel swap is something I'd seriously consider (so it could play Civ III :D ).  I know it is definitely doable on the later clamshells.  I'm just not sure if the models that we have would support that display resolution.  I mean, if my PowerBook 2400 can drive a 1024*768 display via VGA connector, I don't see why this iBook with a graphics card that could walk all over the GPU found in the 2400 couldn't do it.
That said, anyone done a 124*768 swap on the original Clamshell iBooks before? :)
CC_333
Could a 366/466 Clamshell be upgraded to a G4?
One of those with a 450 or 500 MHz G4 and a 1024x768 LCD would be very fun to have, because it could run Leopard somewhat comfortably (though I wouldn't put anything newer than Tiger on it probably). 800x600 for any version of Mac OS X is too small (10.1 is manageable, but in stock form, it's really first and foremost an OS 9 machine).
c
