The MAC MANIAC!
OK if you have seen my post about my CRT issue you know that it has a strange problem. But when i was messing around it seems i broke a rom chip and now my logic board is mostly inactive! After putting in a disk it spun up for about 2 seconds and then cut off. I decided to check my rom chips and see if had put them in wrong. But when i switched them it just made a loud sound as if i made a remix of the Macintosh pluses startup sound. 3rd times the charm right? Well no, its not, in fact i found that a leg broke off of the LO rom.
So i think that getting a new logic board will fix this? Also it makes no startup bong when i switch it on.
Things that work is the-
CRT
power supply
floppy drive
analog board
CRT
power supply
floppy drive
analog board
