How do you open a PB 150 battery?
Quadraman
Does anyone know? Are there screws under the labels that hold the battery together or are they glued/fused together in some way?? I want to replace the cells in mine but I can't figure how to crack it open without destroying it at the same time.
tomlee59
No screws in the original (some third party ones, like some BTIs did use screws). The case halves are ultrasonically welded together. No clean way to separate them. I use an Xacto knife and CAREFULLY work my way around the case.
Quadraman
How do you reseal it??
tomlee59
In addition to glue, there are a couple of other options, depending on what you prefer. One is to use double-faced tape to hold the case halves to the batteries.
Another is to take a soldering iron whose tip you don't care about and just melt the case halves together. Do this in a well-ventilated area; the fumes can't be good for you.
I'm too lazy to do any of these things any more. I just leave the halves unglued, and shove the whole thing into the 'book and leave it alone.
wally
...Another is to take a soldering iron whose tip you don't care about and just melt the case halves together. Do this in a well-ventilated area; the fumes can't be good for you...
tomlee59 is not kidding. I've been working on refining a plastic welding technique for repair of rigid and flexible plastics using a dialed down soldering iron set just above melting point. Great results, but it renders the soldering tip unsuitable for soldering by poisoning the plating, very difficult to re-tin, and will not stay tinned. Also, at a somewhat higher temperature achieved in drilling plastics too quickly, corrosive, smoky fumes are given off that rust a drill chuck overnight. Can't be good for your insides! [;)] ]'>
