AlpineRaven
G'day all,
I am trying to set up BlueSCSI v2 WIFI in my Macintosh LC475.
Specs; LC475 running on full 68040 25mhz, 32mb RAM, full VRAM, nothing else is connected.
BlueSCSI - SanDisk 64gb ExFAT formatted (even tried formatting the SD card in PC, and using SD Card App as well) its not SD card at fault.
Main Drive has those files in the SD Card;
bluescsi.ini
HD20_512 2048mb76.hda
log.txt
NE4.hda
Fresh Installed MacOS7.6.1, along with updated Open Transport 1.3
Also installed DaynaPort 7.7.2 - only selected DaynaPort SCSI.
TCP/IP can see Alternate Ethernet but no IP addresses shows up, as soon I go to AppleTalk to select Alternate Ethernet - it comes up with an error saying that there is no network.
I checked the log.txt - it doesn't show if the wifi that is loaded or not.
Please see 2 attached screenshots and see if I am doing something wrong?
Cheers
AP
bluescsi.ini
log.txt
NE4.hda
Cheers
AP
