Lately I've had a few situations where it would be nice to have an always-on 68k server running System 7 or some such. Since I don't have a spare machine to dedicate to such a role (and don't really want to deal with the space and power consumption of running vintage-hardware 24/7), I thought this would be a great job for the recently-added Quadra 800 emulation in QEMU - it could just live as another VM instance on the Linux box I already run various services on, and I could just connect to it using QEMU's builtin VNC server when I need to mess with it.
If this were an x86 virtual machine, I'd just use libvirt and virt-manager to manage setting up the VM and all the relevant network configuration. The problem is, libvirt doesn't seem to work properly with m68k guest instances - it'll create them, but they won't start because it seems to want to create the VM with a PCI bus, which QEMU (quite reasonably) refuses to do. I've more or less figured out the necessary QEMU command line and network configuration that I need, but before I go about building my own automation to make it work, has anyone else done this (or something similar) before? I'm getting the "wow this is a LOT harder than it should be" vibe that usually means I'm either way off the beaten path, or have missed some glaringly obvious thing that would make my life easier.
