Hello again,
Since I learned that there are adapters available to connect HDI-45 to 2 row 15 pin and then to 3 row 15 pin VGA, I figured there should be a way to make an adapter.
This page: http://home.scarlet.be/~tsc06806/app_moni.htm has a good pinout description for HDI-45 and VGA is ubiquitous.
I noticed that the analog pins are grouped to one side of the connector, making a connection a bit easier.
The pin spacing is a hybrid 0.1" and 2mm, but having them grouped should allow me to use 0.1" headers, soldered onto a perforated board.
Row spacing might be an issue, but I will try to bend the pins so that they fit.
Having said that, here is my question: do you think I can get it to work by only connecting the analog pins?
HDI-45 also has 3 Monitor ID pins that could connect to the VGA monitor ID pins, although I couldn't find a proper mapping anywhere.
Are there any other pins that I might have to ground or maybe even pull-up to enable the monitor to work?
There might be some detection pin that I am not aware of.
And finally, C sync seems to be only available on the HDI and not VGA. No idea what the C stands for either, chroma, composite maybe?
Thank you for any clues.
Please don't be gentle if you think this is insane.
Edit: this site has some good mapping info: https://www.cs.rochester.edu/~kparkins/pinouts.txt
