TimHD
Hi
I am trying to see if it's possible to repair broken traces on the membrane that sits inside an Apple Design Keyboard (M2980) below the rubber domes under each key.
I have 2 of these KBs - 1 almost platinum and another yellowed with age. One works perfectly, one has a number of keys not working. And as you'd guess the good looking one has the issues, the ugly one works fine!
I was just going to swap the insides around to have one "good" KB but it turns out the internals of these are different despite being the same model no (and no mention I could see of different revisions on the net!).
From comparing the keys that aren't working (e.g. characters and symbols up in the top right of the text part of the keyboard and the keys 789 and above/to the right, in the number pad) and looking at where these key's rubber domes strike the membrane and following the traces, it seems that there's a rusting / break in the traces near the connecter to the controller.
See image
https://68kmla.org/forums/index.php?/gallery/image/846-apple-design-keyboard-membrane-damage/
Given this is plastic membrane, I need a solution that doesn't involve soldering irons, to repair these traces. Any McGuyver solutions out there?
See image
