Quadraman
http://eshop.macsales.com/item/PowerLogix/PFZGX10001M/
OtherWorld Computing is selling 1ghz G3 ZIF upgrades.
8-o
8-o
What are you smoking?the G4 upgrade is unstable at best in a Beige G3 system. you would prolly be more happier with that G3 1ghz upgrade. allot of lockup's in Os 9.2.2 slow performance in OS 9.2.2 and OS X cause even tho the software is installed sometimes it only uses 32k out of the 64k available for the L1 cache and sometimes it uses no L2 cache and it showes up as a 60x series of cpu. that is cause the rom and OF only has info for the 60x and G3 cpu's. it will use altvec tho but that wont help much if the cpu is only halfway seen by the system.
What config utility?! Sonnet has the motto "Simply fast" for a reason - their upgrades are simple. They DO NOT MAKE A CONFIG UTILITY. Perhaps that's the source of your problem...for me with the hampered OS 9.2.2 with the sonnet software running and the cpu working i was only shown 32k l1 cache and no L2 cache and showed up as a 60x series of cpu's. i checked over and over in the config utility that everything that was checked was checked and enabled but changed nothing about the cache issues.
Yes, but they haven't been sold for a while OWC has just recently brought them back, which was the point of the post, to make people aware they are back if anyone want's them.er...1.0 and 1.1GHz G3 upgrades have been around for...like two years now.
get with the times man
Surely for that much money you could buy quite a high-end G4 machine though, which would run a wider range of software now that they're trying to kill the G3?i am going to buy one when i have the money.
It's a bug in the way the G4 interacts with the bridge chip on the B&W and the Yikes! motherboards. The page I linked to the OWC site talks about it. There is a way around it but requires additional circuitry on the upgrade board which adds to the cost and results in the lower bus speed, otherwise the G4 can't be made to work with those systems.One thing to note about the Sonnet G4 1 GHz upgrade is that it downclocks the bus to 66 MHz on a B&W or Yikes! machine. I suppose this makes manufacturing easier, and it is in tradition with Sonnet's zero-configuration upgrades. Nevertheless, I don't know the actual reason Sonnet designed the card this way. I think that the 700 MHz and 800 MHz G4 upgrades also clock down the system bus to 66 MHz. In fact, I think the fastest you can go with a G4 ZIF on a 100 MHz bus is 600 MHz with the XLR8/Daystar 7410 G4 ZIF upgrade. No one but Sonnet makes anything faster than that, and Sonnet's upgrades are locked to 66 MHz.
Peace,
Drew
