IIfx
I decided to recap my Color Classic first as the logic board has tons of space to work with. The board wasn't really attacked by corrosion yet so I had caught the cap rot at just the right time. It wasn't booting prior to this procedure.
Instead of trying to tin the SMD leads manually I used solder paste. Easiest stuff in the world to use! If you have to do SMD work and your a total noob like I am go with solder paste, it will save you many hours of struggle. Caps of choice were Aluminum Polymers from Nichicon in Japan. Cleanup was performed using CRC QD contact cleaner.
The system boots right up now, as shown in the photo attached to the post.
But there was a surprise in store. At first, the volume down button was the only malfunctioning unit of the system. System 7 committed Seppuku after trying to format a floppy. The first install disk of System 7.1 could not see the HDD. > <
I pulled out the motherboard again and noticed that I had failed to replace C8! :scrambled: C8 is the small capacitor next to the CPU and FPU. I'm amazed the system ran without it for any length of time. A missing cap is better than leaking ones? Evidently so.
It's 3AM now so I am going to go crash and try to install a tantalum replacement for C8 tomorrow morning. Hopefully that brings the Color Classic back to 100% status.
