file transfer msdos to macintosh system 7.0.1
Wawavoun
Hello there,
Sorry if this basic question has already been discussed here...
I have a .for file which is an old fortran source. This file open properly into msdos 'edit'.
With Apple File Exchange I can read the floppy with my Powerbook 100 but then the file look very strange...
Obviously there are problems with CR, LF and so on...
I try various conversion settings into AFE without any result.
What is the best way to do this transfer and get a correctly formatted file. 80's Fortran compilers are not friendly at all about line formatting !
Regards.
Philippe
I'd suggest using something like an older version of BBEdit Lite, which will happily deal with DOS (CRLF) text files.
Wawavoun
I find a solution.
Original files probably come from an Unix system. Msdos EDIT can handle it correctly but not AFE.
So I open it with Msdos EDIT, simply rewrite it (there is a slight change in the file size) and then transfer with AFE as text file.
After adding a resource files open correctly into Macintosh text editor.
Philippe
