Easter Egg Image Centris/Quadra 610/650
@cheesestraws
ahh i see.. if youre in deep shit you need to do error handling... makes sense 😆..
i'll see if i can rephrase the syscall thing
@tecneeq
one could try to see if the keymap memory region is properly populated when pressing esc + l + f + w. This can be done by entering the debugger and entering "DM 174 " (with space at the end) and then press "esc + l + f + w + enter".. this is bit a hacky method, but it works on my IIci..
DM 174 dumps the keymap memory location and if you put a space after it, everything you enter then is ignored by the debugger.. thus "esc + l + f + w + enter" does not interfere with any debugger command or so...
but I have the feeling that the keymap works fine and the error lies somewhere else, i guess it wouldn't crash if the keymap was wrong
maybe you could also hit the debugger switch when the system hangs and then see where the program counter points to by entering "PC" or dumping all registers with "TD"
Ok, so just tried it with my 650. Keystroke doesn't work. But, the debugger command works fine...with one caveat. If you click on the image after it pops up, the machine locks up solid. Won't even respond to the programmer's switch buttons. Nor does the command-control-power keystroke. So, have to manually reach behind and hit the power switch to shut it down.
So, just with regards to it not working for everyone. I think I remember that there are two ROM versions fitted to the 650.
To be clear, I have a *Centris* 650, that shipped at 25MHz, so it is an earlier 650. Might everyone else have the updated ROM?
Mine is also a stock C650 that shipped with a 25MHz '040 chip. I did upgrade it with a 33MHz chip, but the computer still reports itself as being stock, since I haven't changed the resistors on the underside.
Hi. I have tried the tools with the ROM of a DuoDock to find the Easter Egg, and there is a problem with the file.
It's weird : it works with another ROM dump, but with this file, i have an error. I can add the FF at the end, but the image is not complete.
Can you help me ?
What is "the tools"?
That ROM appears to be a NuBus Slot ROM for a "Macintosh DuoDock II". It is 128K in size but only the first 64K is valid.
I can parse the ROM if I copy the FHeaderRec from the DuoDock ROM (the last 32 bytes of the ROM). However, some parts may be missing.
The last slot resource has address E634C. It has length 00ABA6 which extends beyond the 64K of valid data.
Also, note that QuickDraw pictures are not viewable in modern macOS. You should use QuickTime or something to save it as a png file. I looked at the picture in SheepShaver SimpleText. The picture has a few lines worth of invalid bytes at the end. Where did the picture come from? It does not appear to be from the DuoDock II ROM.
The tools refers to the tools from #16
Code:
# Get macintosh-rom-easteregg-hunt
cd "/Volumes/Work/Programming"
mkdir "macintosh-rom-easteregg-hunt"
cd "/Volumes/Work/Programming/macintosh-rom-easteregg-hunt"
git clone https://github.com/nerdprojects/macintosh-rom-easteregg-hunt.git nerdprojects-macintosh-rom-easteregg-hunt
#Cloning into 'nerdprojects-macintosh-rom-easteregg-hunt'...
cd "/Volumes/Work/Programming/macintosh-rom-easteregg-hunt/nerdprojects-macintosh-rom-easteregg-hunt"
# Test it
thefile="/Volumes/Storage/Downloads/DuoDock II ROM/DuoDock II.ROM"
./extract_PICT1.py "$thefile"
./extract_PICT2.py "$thefile"
./extract_bitfield.py "$thefile"
found PICT2 header at offset 0x6598 with PICT size 0xd252
end byte not matching 0xff
writing file to ./output_bitfield/DuoDock II.ROM_INVALID_0x6598.pict
extract_bitfield.py finds the picture in the incomplete sResource that I mentioned previously.
The second half of that DuoDock II ROM likely has additional useful data, so it'd be nice to get a complete dump.
Regarding the original point of this thread, ESC+L+F+W works great in MAME.
Edit to add: ESC+S+E+T works for me on the Quadra 900 but not the 700.
I have used this tools : https://github.com/nerdprojects/macintosh-rom-easteregg-hunt
And yes, it's a Duo Dock II ROM. The picture is an Easter Egg from this dock (https://www.journaldulapin.com/2019/02/20/easter-egg-duo/)
For the image, i use an old Mac to convert the picture, but this one is invalid. I have made the same things with the Mini Dock, and it worked.
Code:
# Test it
Exactly.
For the dump, i have launched SlotRom (https://www.gryphel.com/c/minivmac/extras/slotrom/).
Have you another software to dump the ROM from the Duo Dock II ?
