sircabulon
I have a beige G3 (check signature) that I want to be able to play DVD's on. VLC kinds sucks for that because you can't do anything else while using it and even still it has a slow frame rate when running independently. I tried doing the hack where you delete the "Install Check" file inside the DVD Player update package, version 3.1.1, and got DVD Player to install. The actual app itself wouldn't open, so I then got pacifist and used it to install the version that came with panther. It will open, but it says that it cannot find a valid DVD drive. I then researched more into it and found an alternative application, but cannot get the stupid file to download because of some sort of microsuck server error on the other end. If anyone has solved this problem before, please help me out. Even if I could get it to work in classic, it would be good enough for me.
