JRL
So I picked up a dual floppy SE with a Radius Accelerator 16 and a Radius TPD card (along with the TPD monitor) several weeks ago. Right now it's not booting so I am attempting to check the card to see if it's fitted ok (the two boards seem to be a tight fit currently)
The problem is that I can't slide out the SE motherboard because the MagicBus card connector is in the way of the frame. What would be the best way to remove it? I have a hunch the answer is obvious but I am genuinely stumped.
Thanks!
-J
Thanks!
-J
