Yep can print them here:Yes, mine doesn't have that riser piece on the frame. I seem to recall encountering it years ago, not knowing what it was, and removing it since it was in my way. Ouch.
Anybody have a 3D model for a printable replacement? Or a riser from a dead SE/30's frame they'd be willing to sell?
If not I have a spare case I can pull one from if @bigmessowires wants a metal one.Nice! I sold an extra a few years ago; it was the last free one I had. Hope that plastic one gets you going.
Thanks, that might be best if you're willing. I don't currently have a 3D printer and the model notes "You may have to experiment with rafts and supports to get a good quality print." Having a 3D part is awesome and I'd definitely try that first if I were more literate at 3D printing.If not I have a spare case I can pull one from if @bigmessowires wants a metal one.
4-40 works with my SE/30
That is some kind of self tapper you have. Make sure it isn't meant to be a metric machine screw of some kind. I can't tell which screw you mean exactly, a picture would help.No worries, I'd assumed it was a common screw. After lots of experimentation, I discovered it's the same as the screw that attaches the ground wire from the power supply. I'm going to bring that screw to the hardware store and use it as a reference to get more.
Huh, I'm positive that some of my stash are #4-40. Actually, my ground screw (which fits) looks different than the screw you pictured. The thread is more coarse:
Yeah, the finer thread there looks like a metric machine screw. Apple like M3.5 screws which can be tricky to find. If someone can clearly tell me which screw it is, I can measure on from my machine.The coarsely threaded ground screw will fit in the finer threaded bracket screw hole, but it does not belong there, and will distort the hole in the process. My screw gauge kit does not have a gauge that fits the course ground screw.
The picture below shows that the ground screw has coarser threads.
It's the three screws that attach the PDS card bracket to the rest of the frame, circled in red in the photo here: https://68kmla.org/bb/index.php?thr...e-backplate-for-a-pds-card.45756/#post-507475If someone can clearly tell me which screw it is, I can measure on from my machine.
OK, I will get some more 4-40 screws and try again. I'm almost sure that some of my mixed screw collection are 4-40, but maybe I'm wrong.Pic of the screw fitting perfectly in the 4-40 gauge, which itself fits perfectly into the bracket screw hole is below.
