Digidesign Audiomedia REV B-1 & Quadra 700
System7
Banned
That looks like an audiomedia I. I have the drivers for the Audiomedia II, and it wont work. Try finding the II as it has a DSP.
Unknown_K
I have one of those cards, came with a very early AVID setup originally in a IIci.
You will probably have luck with old software that has drivers for that card directly.
Ofcourse newer cards will have more features, depends what you need to do.
somorastik
I just saw a nubus card, and I mess around with audio midi & stuff with the old 68k, so what can I do with such a card?
I have no idea of its capabilities.
Bunsen
Admin-Witchfinder-General
It has better quality analog to digital and D to A audio converters on it than the ones on the Quadra.
I am quite sure there is a DSP (digital signal processor) chip on the Audiomedia (1) card. The difference with the AMII is that the II also has coax digital S/PDIF in and out (an extra pair of RCA plugs on the back)
USE THE SEARCH FFS
[:(!] !]'> [}:)] ]'> [xx(] ]'> > :( ::) :p [}:)] ]'> [:(!] !]'> [V] [xx(] ]'>
both the forum search here (audiomedia), and google audiomedia nubus site:digidesign.com
somorastik
I will google that up, thanks and sorry.
Could I possibly do the following.
I have an Alesis Multi Mix 12 Firewire, with digital out, plug that into audiomedia card (I or II ???) and record multitrack from the mix?
With a Quadra 700 probably?
Thanks
:I
