Dennis Nedry
I decided to work on my old Mac IIci today. It was stored outside in the weather for several years before I got it. The ports on the back are a bit rusty and there are signs of capacitor leakage. The Mac does not make any sound or attempt to boot. The power supply does come on however.
So I thoroughly washed the logic board and I discovered a deep scratch across some traces in the very center of the board, near where the screw goes through that holds the plastic floppy/HD chassis. Upon testing, indeed, several of these traces have been severed. These traces connect the large chip labeled "RBV" to the four 74F245s that appear to swap the ROM based on the ROM Select jumper. But I'm not too sure on that.
After a great deal of very diligent work, I have reconnected each trace at each end where the scratch had gone through, including some that tested good. I re-tested at the end for any short circuits between them an all appears well.
I plugged it in, like a kid on christmas expecting something extraordinary, and again NOTHING. So I decided to whip in a Mac IIfx ROM SIMM, remove the jumper, and see what happens. Interestingly, it made a startup sound, followed immediately by a crash sound, no time in between. This verifies some of the hardware including the processor and sound circuits and tempts us because we see a sliver of life peeking out at us.
Hooking the Mac to a monitor reveals no video. (Drat, no sad mac error code.) Removing all RAM results in a silent crash immediately after the startup sound, evidenced by the interrupt button not causing a crash sound. The ROM select jumper makes no difference, it behaves identically in any situation I could conjure, with and without that jumper in place.
So what do I do now?! The board is freshly cleaned but it still has the old caps. There aren't really any caps that are obviously involved in selecting which ROM to use, which appears to be somewhat of an important clue. Any ideas are welcome.
