Daystar PowerCache 50 MHz on SE/30 ???
pfuentes69
Hey,
I got a Daystar PowerCache 50 that I was initially thinking to add to a IIci, but now I'm thinking that maybe the SE/30 could be a nicer host.
Does anyone has experience with this?
Where could I find the adapter board?
Is it compatible with the Rominator II?
Thanks!
zigzagjoe
@Bolle sells combo adapters that are both NICs and provide an IIci cache slot as well. I believe it is compatible with Rominator too.
Otherwise you will have to hunt down one of the twinspark or original daystar adapters.
pfuentes69
Thanks. I sent @Bolle a PM
Actually I just need the simplest possible adapter... I have a RASCSI in the SE/30 and that gives me networking too.
This is the original...
ttb
I also run a 50MHz PowerCache in an SE/30. It runs A/UX 3.0 acceptably fast.
JC8080
Here's a pic of my adapter and 40mhz card, I use the same adapter with my 50mhz card.
