BadGoldEagle
Hello
I'm going back home for a couple of weeks in March so that means spending more time with my Macs!
I had Mode32 installed on my SE/30 but for some reason it was the wrong version for 7.5. Having the wrong version installed can completely screw up your hard drive. And in my case, it kinda did. I removed the old version and reinstalled the correct one but unfortunately, the computer boots in 32bit mode only 10% of the time. I don't want to reformat the hard drive and lose 30+ years of work. Plus having a 32bit dirty ROM isn't necessarily great.
So, TL;DR:
I'm going to get a GGLabs MACSIMM (if they ever manufacture new ones... otherwise I'll have to get it done somewhere else) but first I'd like to know if there is a modified SE/30 ROM floating around somewhere that has the following features:
- 32 bit code
- SE/30 Gestalt ID (#9): I'm running a small hack for 7.5 that shows what machine you're using when you click on "About this Mac" (like on 7.1) and I don't want it to show a IIsi or something...
- ROM/RAM check disabled
- HD20 support (for transferring files on the Floppy EMU in HD20 mode)
I've looked online, I'm sure I've come across one that fits my requirements before but I can't find it now... Any help appreciated!
Thanks!
BGE
So, TL;DR:
- 32 bit code
Thanks!
BGE
