Hi all!
I just got a beautiful Classic II!
(ok I know I need to recap it as soon as possible)
Turned it on and worked.
But I opened it to do a quick checkup and probably I was the first person to do it. It had no marks inside at all, everything was in its perfect position. Just some dust but not that much.
I looked at the mainboard and there is no sign of leakage but as soon as I return from my one week trip to Rio de Janeiro I will recap it. I just washed the board, let it dry for a couple of days and it is still working.
But I noticed it doesn't do the chime startup sound. There is no sound at all. Even inside the system (7.0.1).
I tried to check the volume using sound control panel but it gives an error message:
Maybe a faulty IC? Or just recapping will do the job?
And I have a question: I networked it with my Beige G3 Desktop running OS 9.2.2, using a simple printer cable via parallel localtalk and was able to receive some files from it. The question is: can I browse the web on Classic II using this setup, the G3 providing some sort of bridge between its ethernet and the localtalk?
Thanks in advance.
Thanks in advance.
