JustG
As I alluded to in my SE/30 thread, I'm also working on a Classic. I've running into an issue when plugging my FloppyEMU into the external port of the computer. When in floppy emulation mode, I am able to select a disk image but the moment the computer begins to access the image, my FloppyEMU will go into a power reset loop, it will get to the self test screen, power cycle and repeat.
I've recapped the logic board and replaced the leaking caps on the analog board. Voltages have been adjusted and are holding steady with several tests. If I plug the FloppyEMU into the internal connector, no problems at all.
This isn't the end of the world but I would like to know if I can fix the external port. Way easier than cracking the case to plug in the emulator.
