go ahead and tell me how bad the 5200 is; frankly, I'm buying one for pure nostalgia)
The 5200s are valid, worthy of love, and to be perfectly honest, nowhere near as bad as Low End Mac has spent the last 20 years fleecing people into believing.
If you install Speed Doubler 8 or have a PowerPC native build of ClarisCAD, it'll run perfectly fine on the 5200. If it ends up not being a very intensive program to start with, it will also run fine.
The 5200 is a meaningful boost over the 500 series with the 832x624 display and should be meaningfully faster than, say, an '030. I have a 6200 and it can even run OS 9.1 and Office 98 and Internet Explorer 4 and 5, although it's not
great at all that. I've said this a bunch of times, it's about as fast as a PowerMac 6100/60.
There was a recall, on a fairly large number of units, but any that survive today
probably don't have the bug that caused the recall.
longtime MacDraw II user (29 years with it)
Just by way of semantics: Have you been
actively using MacDraw II for 29 years, or did you use it 29 years ago but not develop it as a skill or exercise the skill the entire time? Computing-centered/oriented skills, like any other, get rusty when not maintained.
(I'd also argue that there's a difference between basic maintenance/use of a skill and
development of it. Even if you've, say, spent the last decade designing worksheets in it as if it were a page layout program (which, it should do), that's different than spending time actively working on doing more complicated/technical/involved things with it. Although, how much that applies to MacDraw kind of depends.
In my experience, most modern big software packages have a couple of different attendant skill levels and in various situations whether or not moving to the next skill level is advantageous really depends on the type and scope of problems you need to solve with it. I.e. it may or may not be worth learning semantic styling in a word processor if you never need to create multi-page documents.
The strength of the program appears to be its ease of use and documentation. I have seen the telephone directories AutoCAD comes with.
It would be interesting to see, from an experienced CAD user if possible, a functional comparison between them. In my experience, a lot of what made Claris software so interesting was basically split between two separate things: What they left out compared to bigger and/or more expensive software, and, the commitment to The Mac Way.
