Case screws for an SE/30
Frotz
New member
An SE/30 I've been fooling with for a while is missing the screws that go underneath the carrying handle. Does anyone know the exact specs for these screws? Do you have any to spare?
beachycove
As I recall, the ones on the bottom are the same in size, only a different colour (top ones being black, & bottom silver). You should be able to find replacement screws easily enough at a hardware store.
Apostrophe
It's actually the opposite, at least as far as my Macs go. Now, I don't know about an SE/30, but my SEs and 512k have black screws at the bottom, and silver ones in the recess.
-Apostrophe
equill
More to the point is that the dark bottom cheesehead Torx screws have a metal thread to mate with holes in the metal chassis, and the top 'silver' cheesehead screws have a coarse thread to mate with the corresponding holes in the bezel without ripping the thread out of the ABS plastic when they are overtightened. And to restate the already well-known, all of the screws have recesses in their heads to mate with a Torx-15 driver (splined cylindrical tip) that has at least an 8-in shaft. The driver doesn't need to have a central (axial) hole in the tip because the screws that Apple used are not security screws (Resistorx or Pin-Torx).
de
Damian Ward
Part numbers for the screws are, 426-1007 for the silver and 435-5002 for the Black. You will probably have no luck with Apple, but someone may still stock them.
Frotz
New member
It seems that someone sells them, but for $58 apiece. Any idea on the specs of the screws (thread, length, diameter, etc)?
porter
A cheaper solution would be to buy an old SE/30 and remove the screws....
wally
Thread spec by measuring a sample:
Size #8 USA standard self tapping screw
Standard USAS B18.6.4-1966
Type AB:
18 threads per inch, right hand thread
Major/minor diameters .163 OD/.119 root (inches)
standard 60 degree thread form (there exist designed for plastic custom metal screws with a more acute angle but these are not that kind)
Point type B
Nominal length of shank: .625 inches
If you inadvertently substitute the common Type A self tapping screw with nearly the same major and minor diameters but 15 threads per inch some serious cross threading and thread destruction in the housing could result .
Scott Baret
I'm sure if worse came to worse you could find non-Torx screws to fit those specifications.
Also, if you are taking apart Macs, be careful not to confuse the Torx screws that hold the chassis and CRT in the computer with the case screws. Some later model Classic IIs actually had gold-colored screws for the chassis and CRT to prevent confusion. The silver screws look nearly identical except the chassis/CRT ones are shorter. If you use these in the case it won't fit together, and if you use the case ones for the CRT, you'll get what resembles a huge pimple on the other end of the case...
