Nope? That’s a thing?Have you seen @max1zzz's IIcx clone board?
Is was wondering if someone tried to clean cap goo with something even nastier? Put something on it and left it/forgot about it.I didn't think it was cap goo either but it's uncanny that its only in areas where there are caps. It's quite tough to remove with a toothbrush and alcohol I need to get something better definitely has been eating at the board though whatever it is.
Yeah, this is super weird. Whatever method you attempt to remove it, it might make sense to take extra precautions for self-protection - gloves, perhaps eye protection and mask, and good ventilation - no idea what might be getting airborne.I didn't think it was cap goo either but it's uncanny that its only in areas where there are caps. It's quite tough to remove with a toothbrush and alcohol I need to get something better definitely has been eating at the board though whatever it is.
Use litmus paper to check if it is acid or alkali, and how strong for safety, then use the opposite to neutralise, check with litmus paper that it worked. You can buy books cheap on Amazon. It's a good idea to have some in the house to check when you don't know what you're dealing with.I'm not even sure what to suggest what products to use, not knowing what you're dealing with... perhaps test a small area with vinegar, another with baking soda, see what happens.
I like it!Use litmus paper to check if it is acid or alkali, and how strong for safety, then use the opposite to neutralise, check with litmus paper that it worked. You can buy books cheap on Amazon. It's a good idea to have some in the house to check when you don't know what you're dealing with.
