chrisrueckert
I noticed that both of my blueSCSIs don't recognize the "bluescsi.ini" file. The log file states: "Config file bluescsi.ini not found, using defaults"
I "nuked" the blueSCSI and updated to the latest firmware. No change in behavior. Any thoughts on what the issue could be?
Update: Typical beginner's mistake: I used the https://ini.bluescsi.com/ , downloaded the file and adjusted it to incorporate the ROM disk settings I was after - appears that the file type was the issue. All good now.
