Okay. Twisting SMT (surface mount) capacitors to get them removed is very risky. You can end up not only lifting the pad but also ripping the pad and trace along with it. Then you'll have no other choice but to repair the entire connection, and that isn't easy. This would involve sitting down with a pad of paper and a multimeter with continuity tester to trace out the circuit path. Then you'd have to solder a very thin wire (enamel coated or similar) from the origin to the destination, creating a bypass. Sometimes you can't make connection from the top or you'll end up tracing to underneath the logic board.
These are reasons why I don't recommend it. If you want to do it the safe way, just use 2 pencil soldering irons of the same watt value to melt both ends of the SMT's contacts. Then, when the solder is melted enough, simply lift the part out and away using the iron's tips like a tweezer. I'd recommend no more than 40 watts of power for the irons and make sure they have a small diameter, fine tipped tips.
While you can use electrolytic caps to recap a board, remember that you might have to go through the recapping procedure again in 10 to 15 years. If you use Tantalum SMT caps (like what 68kmla member Trag sells), you are given a much longer lifespan out of the job done.
I do SE/30 board recaps from time to time and I follow the above method as I did the research. It's a little extra work, but it is much more safe and more successful at getting this done.
73s de Phreakout. :rambo:
