Schmoburger
As the title suggests, my beige G3/300 Minitower running OS 8.6 will not display networked computers in the Chooser, nor will it display anything in the Network Browser. I think I have mostly ruled out a hardware failure or incompatibility (including a bad cable) by the fact that it connects to the router and correctly negotiates IP parameters via DHCP, as well as seeming to have no real issues browsing the net, outside of those caused by the incompatibility of IE4.5 with almost anything on the modern web. The problem would appear to affect Appleshare specifically.
I have my 9600 powered on, with sharing started up and all drives shared, and ethernet being the selected connection for everything, running OS 9.2... It functions 100% correctly, connects to network volumes on my G5 properly via the IP address workaround in Chooser, and the clone running 7.6.1, the IIvx running 7.5.3, and the CC running 7.1 are all able to connect to it with no issues at all, and it can connect to them, So by rights there should be no incompatibility between it and the G3 running 8.6 and connected via the onboard ethernet, yet for some reason it refuses to work.
Anybody got any ideas? this one has me stumped.
I should point out also, that this is a brand new virgin install of 8.6 on a freshly formatted drive... the computer has seen about as much use as was necessary to try and work this out, so there hasnt really been enough use or changes made to degrade or break the system.
