karrots
I recently connected a Macintosh Classic (7.5.5) to Ethernet via an Asantetalk bridge. I can successfully mount a file share from a Basilisk II VM and copy some files from the Classic to the VM.
There are two odd things. 1) originally when I tried to mount a share from the Classic into the VM it would fail on the last step. From VM to Classic it worked fine. I could transfer files from the Classic to VM.
2) Day two I tried to copy files from the VM to the Classic and its super slow. Often the share disconnects in the middle of the transfer. To get the devices to see each other again I have to reset the Asantetalk device.
Any thoughts do I just have a bad bridge? Similar things happen connecting from Classic to a netatalk server.
The switch I have the Asantetalk connected to shows a 10/half link with no errors.
