3lectr1cPPC
I’ve got an original AEK with a bad left shift key. I took the assembly apart and noticed some corrosion in one area and I cleaned it up. Two traces are bad and I traced one of them back to said left shift key, great! The other leads to an option key.
So I traced the trace all the way to a pin on one of the ICs and soldered a bodge wire. Now the shift key acts stuck down at all times. Any ideas?
