Anything I should know before I do a flyback replacement on a trayloading iMac?
68kPlus
I bought a new flyback for my iMac G3 grape (rev c), and was just wondering if there's anything I should know about before replacing the flyback.
I have left it off for about 2 weeks (although I'll discharge it anyway), and I've already taken it apart several times, so anything I should remember/shouldn't forget?
Also does anyone know any easy tutorials on replacing it (like where the correct wires go, etc)?
Thanks,
68kPlus
joshc
The Apple service guide for your model of iMac should include the procedure to follow. Take pictures as you go and use a tray for screws. Good luck.
CYB3RBYTE
To my knowledge no, there's nothing specific other than to note the orientation of the the original flyback, and I'd also guess to make sure your solder joints are good and the rest of the board is in good condition too.
68kPlus
Awesome. Yeah the flyback only goes in one way anyway, and as far as I know the whole iMac is working fine aside from the stupid flyback
And don't electrocute yourself. That time you did off the compact Mac PSU doesn't compare to what a CRT will do to you.
68kPlus
Lol you didn't forget that XD
Yeah good point, hence keeping it unplugged for like 2 weeks and always discharging to my house's ground point outside.
68kPlus
Just gave it a go - Success! Will upload pics later.
Needed to buy a new 80W soldering iron and some 3mm wick, and it worked!
So glad
68kPlus
Thanks @Phipli - I was shaking a bit when I turned it on!
Some photos (left to right):
Early version of my screw page, had a lot more afterwards.
New flyback
CRT neck
The boards themselves with old flyback
Finished result
I didn't take many photos because it was a lot of work and I was anxious about it, but at least I have a few photos
