tmtomh
Hi all,
I'm familiar with all the woes that afflict iMac G3s, but I have a situation that's a variation on the theme, so I'm hoping for some help, or at least some perspective.
The basics:
- iMac G3 slot-loader; 350MHz upgraded to 450MHz via a mobo from a 450MHz unit whose PSU died.
- I upgraded the mobo, added RAM, updated the firmware, installed OS X Tiger, and swapped in a larger HD. Somewhere relatively late in that process, the machine became unstable, often shutting itself down right after startup, and when trying to wake from sleep. The original 350MHz mobo sometimes had wake-from sleep problems, but these never included a shut-down; and with a 400MHz mobo swapped in, the machine had some video corruption (not from the analogue circuitry but from the mobo itself), BUT it ran like a tank otherwise, always waking from sleep and always starting up properly.
- Back to the current situation with the 450MHz mobo - here's the really weird part: I can always get it to start up properly if I zap the PRAM. The PRAM battery is good though, reading 3.57V on my volt meter. I've also reset the PMU via the mobo CUDA button.
- I've swapped HDs in and out, swapped all the RAM (modules and slots), checked, adjusted, and replaced the internal power button (sometimes they tend to get stuck), swapped keyboards, and tried running without a PRAM battery installed. The situation is always the same though - 9 times out of 10 the unit will not start up properly unless I zap the PRAM; 9 times out of 10 it will turn itself off when I try to wake it from sleep; and if it does wake from sleep properly once, it will not do it a second time.
- The common behavior when it shuts down - whether upon startup or upon trying to wake from sleep - is that the HD does not spin up when it is supposed to. So when I turn on the computer, the HD does its initial spin-up, then the grey Apple appears, but then right when the little "spinning gear" should appear and the HD should start loading the OS, the screen gets a darker shade of grey and the computer shuts down. Similarly, when I try to wake it from sleep, the pulsing amber light changes to solid green (as it should), but the HD doesn't spin up, and then the whole machine shuts down.
Any ideas WTF is going on here?
I would chalk it up to the PAV/analogue circuitry problem - but the fact that I can always startup the computer by zapping the PRAM, and that the HD seems to be involved (and keep in mind it's the same with two different HDs), makes me wonder if there's something else going on that I'm missing.
Could it be a hopelessly crashed PMU? Is there any possibility that the IDE cable could be to blame? I realize I'm grasping at straws here, but before I give up and part this thing out I want to make sure there's nothing I'm missing or overlooking.
TIA!
Best,
Matt
The basics:
TIA!
Best,
Matt
